Topic: Sing? (Read 2473 times) previous topic - next topic
Sing?
You can make a fair amount on cat converters.  I sold three of them on ebay for $120 (for all of them) awhile ago.  I'm sure you can get more if you separated the metals yourself.
1987 Thunderbird 3.8. Sold :(
Sing?
Quote from: DVP;239218
CLEAN... I got screwed on that. I carried in my intake in one piece with one bolt in and they weighed it as breakage because of the bottom but the top was clean I just didnt get the chance to take the one bolt out. Well the truck is down so I dont know what is going to happen with this washer and dryer. Ill be breaking down the freezer and stove Friday
Take your time and work every piece over before you take it. Then don't forget that if that say breakage you always can say oops sorry guys and take it back and finish cleaning it up. Then you need to pull things apart fully even things that are made together. That Fridge you have take the coil and cut the ends off so you are down to the base core. The more you do to strip it to base the more $$$ you will get. Think of this a Big truck RAd that I took in was $75 dirty, took it home and finished it up and I got $150 for it. even though it was one piece I cut the tanks off and got the center core that was worth a lot more than the rad as a whole. Take your time and make sure it is seperated.
