Topic: 87-88 thunder bird tranny question (Read 1065 times) previous topic - next topic
The v8 and v6 transmissions from a 1987 and 1988 (respectively) thunderbird are the same size, but there are different internals right?
The v8 transmission has bigger or heavier duty clutches and stuff right?
The v8 has more clutches.
Also, I believe the V6 trans has the smaller C overdrive servo and the V8 trans has the B overdrive servo.  So far my V6 trans with the Transgo is still holding up behind the 5.0 HO with 100K+ miles, but I don't drag race it.
1988 Thunderbird
306 HO w/ A9P processor
AOD w/ Transgo Reprogrammer
245/50/16 Tires on Snowflakes
