Topic: Help I need these wires identified, 1988 Cougar (Read 2086 times) previous topic - next topic
I don't have a wire diagram and this car was taken apart before I bought it so I'm not sure which wires these are. They are all located under the solinoid near the coil.
Wire #1
has 4 black with green stripe that go to one wire and has a connector on it. (ground?)
Wire #2
has two black w/ white strip wires with a connector on it, it comes out right at the window washer solvent bottle.
Wire # 3
has a single yellow pink strip that has a connector on it (blade connector)
the pics are in order 1,2,3
more wires :(
I found this burt fusible link too
It is gray with a yellow strip.
anyone? I tried to start downloading the pages of the manual that Scott posted so I can read them but they are not coming in for me. I got a couple than they started coming in with just a small single dot in the middle after I clicked save
Is the manual located anywhere else possibly in a single download?
What engine?
What do the ends look like? It's sometimes a give away.
I've got connectors all over my 3.8 that go nowhere.
1988 Xr-7 with V8, the connectors are in the pictures
the problem with the evtm you had is the first ive heard of this.  Ill check it out.
Wire #1
Not sure yet
Wire #2
Mine does have a home down low near a diode that flips back one of the blacks into a larger harness.  The connector should be there hidden ill bet.
Wire # 3
Mine transitions into a blue wire that i suspect if for the oil level sensor.
Check the side of your oil pan for the sensor and sneak out the wire,, maybe its hiding to.
Ok wire #3 makes sense because I have an aftermarket milodon pan so no sensor now. Do I have to do anything to this wire to make it not read low oil?
As far wire #1 goes isn't there a small ground wire that attaches to the negitive terminal? My car didn't have a ground wire at all so I'm not sure.
Any word on the fusible link? I was just curious what it was before I replaced it.
thanks for the help btw..
Quote from: Bob;236999
The battery ground cable should have a small "pig tail" wire that goes to a connector near the battery.
It is a blk/lg wire and goes to pins 40 and 60 on the EEC, the HEGO sensors and EEC power relay.
You should not be able to start the car if this ground is missing from the EEC power relay coil.
Quote from: softtouch;237003
thanks, keep' em coming just a couple more now.. :hick:
Quote from: jcassity;236998
the problem with the evtm you had is the first ive heard of this.  Ill check it out....
heres what I did. Opened link, click on pic, clicked full size, right click save on full size photo to a folder on my desktop, than I went to the next one.
heres a screenshot, some pics came through (the ones that have a thumbnail for them in the folder) the others have file size but 0x0 resolution.
ok
tested out the situation.
what i did
I did not log in to my account, just clicked on the link.
I double clicked the page i wanted to view.
the page poped up.
Next
I went to the file on my HD
Right clicked on image
open with "Paint"
opens perfect.
SO,,,,,,,,
You should be able to right click on your image
open with paint
Quote from: jcassity;237147
ok
what i did
the page poped up.
Next
open with "Paint"
opens perfect.
SO,,,,,,,,
open with paint
I'll give it a try, thanks again.
