Topic: It just died! FIXED Updated 7/28/2010 (Read 5254 times) previous topic - next topic
What about your engine ground? Heh, it's worth a shot. I had a geo metro that acted funny because the engine ground lug was corroded.
CoogarXR : 1985 Cougar XR-7
I just double checked it. All four of them that I have now. Don't find any problems with the grounds. I did do some searching and over a turbo ford they said the TPS out of wack can cause something like that. Well Checked and it is set at .97volts and has no drop out  in the full range all the way up to 5volts. I unplugged it and did my run until she dies and still dies once she gets warmed up. Humm still plugin away slowy sometime I'll get this lined out.
Stuckman
I read through this once but can't remember if you tried another EEC?
If you need an LA3, I have one for sale...
Keep on pluggin, you'll find the cause soon :D
I hate to say it but it sounds like you are at that point where finding a car with a donar harness would be cheaper and faster.  Sometimes a factory harness gets so hacked up and brittle that you just cannot find the problem(s).  I did a little searching and found a company that makes them brand new so it might be worth a look.  Kind of pricey but the fact that someone even makes them new is a miracle:
http://thedetailzone.com/Ford%20Replacement%20Harnesses.htm
The wiring harness is about 3/4 the way down the page.  They also make 5.0 harness and all kinds of other ones.  I checked Painless but they do not show one for the 2.3L.  They make a great harness for the 5.0L which I have.
Darren
I've got this all worked out. I found that the PIP"pickup" was over heating and shutting down. I had a new one and a used one. Both did it. Found out the new one was Toast. After replacement I let her run for 20+ min in the driveway. She ever shut down. So Yesterday I took her out and got and inspection. Passed right away then a quick trip to the DMV and She all legal again. Nice to have my birdie back.
Stuckman
It didn't throw a code for the pip? The one in my 95 died and didn't throw a code. I replaced it and the car has been fine since.
Quote from: ipsd;329768
Stuckman
Glad u got that sorted out!
hell you even tested the pip and passed it. What caused it to be fried?
Got that fox rash again!
-Resident smartass! :ies:
Quote from: Cougar8775;329796
Many times you can test an ignition module and it will test okay. It's not until it heats up that it breaks down. I always say if in doubt replace it.
Reply #39
Well I guess it isn't really fried it will work for bit then heat up and shut down. After hours and hours of probing wires and swapping parts. I took back the A1-Cardone Dizzy that I purchased and warrantied it out for another unit and that fixed it right up. Why this happened I don't know. I guess something in the PIP went south and caused it to heat up and stop sending the Signal to the TFI. Just glad its all back in working order. Now on to the many other task that need to be tackled.
Stuckman
