Topic: And so it begins (Read 1025 times) previous topic - next topic
And so it begins
I just bought a 6" Cone Filter (K&N) for the TC. Getting rid of that stock air box will be the first real performance upgrade I've done to the TC, other than the 245's. The drop in oval K&N doesn't count, and hasn't made any difference either way.
I was going to get the Gillis valve first, but since I'll have this thing installed a good month or two before even get to drive it, the boost valve will be bought and on anyway. I may as well do the two together, right? :)
Anyway, goodbye stock airbox. :flame:
Re: And so it begins
im doing the same thing tonight, im just mounting mine on the VAM
you probably read my other thread, but i bypassed the stock BCS, that gave me about 17psi, which is alot of fun!
So, do I need the Gillis then? How do you bypass? Just link the vaccum lines going in and out of the BCS? I don't know, sounds a bit risky to me.
DUDE, i got the VAM mounted K&N, and its an amazing difference
to bypass the BCS, all you do is disconnect the lines, and connect them together, its really simple, but watch your boost gauge the first time you go WOT, because each car does act a little different
with the VAM mounted K&N and the BCS pypassed, i got 18psi
BlaaaahsassinfrassinfornicateinRIGHT! 18 psi? Awesome, man.
a gillis would be ideal, so youre able to turn the boost down if needed though, forgot to mention that
