Topic: turbov6 (Read 4572 times) previous topic - next topic
turbov6
what year of an f150?
turbov6
97 and up
turbov6
will i have to change my trans or anything else?
turbov6
and how much boost?
turbov6
Time to sound like a dick, since I'm good at it.
You have to learn more to accomplish your goal. You don't just put a turbo on an engine, and go "yay, I have 400 horsepower". You have to learn about the computer system, how you're going to tune it, how you're going to keep up with the fuel demands, what to do about your ignition system, what turbo is appropriate for your goals, how you will mount said turbo to your car, how you will plumb it, intercooler or no intercooler, strength of the engine, strength of the transmission, strength of the rear, the body, the suspension, and so many more factors before you consider it.
Or...you can ignore me, slap something together, blow it up, and be mad at the world.
turbov6
i know all of that, i just want to know if the 4.2 will bolt up to my AOD and how much boost psi the block will hold before it gives?
turbov6
http://www.google.com
turbov6
Start with a supercoupe V6 and trans.  Add two IHIs with ICs.
Keep us posted on the results.
__________________
Twin '85 TCs
White/ Grey 2-tone
turbov6
Quote from: wnt2gofst;236525
So explain your setup plan.
turbov6
like everyone said you must have aleast a good idea on what your getting yourself into and how you want to build a turbo v6. it not easy at all. i am still finishing my plan on paper to build my turbo 4.2 v6. while i buy the big parts.
turbov6
The 3.8 is called the head Gasket hog,even the front wheel drive 3.8. U could Turbo it but it would be less heace to turbo a 5.0 or even buying a TC or XR-7. Or get a SC and build a custom if you really want to build a 3.8.
turbov6
88 TC with 93 GT 5.0 (.030 over), XE266HR Compcam, SVO 1.6 Roller Rockers, BBK underdrives, BBK 1 5/8" headers, 2 1/2" exhuast with Americian Thunder Flowmaster lers. Tremec 5 speed and 3.73's and alot of other goodies to list.....
turbov6
Quote from: Tbird232ci;236717
What plan???
turbov6
Quote from: 88TurboCoupeman01;236745
First off, WTF is a "heace"?
He wants to know about putting a turbo on a 3.8/4.2, not a 5.0, or anything else. I'd say that Shawn's post pretty well summed it up...you didn't need to spew nonsense about it...course, I didn't either :flip:
Then again, what could I expect comin' from a guy with 30# valves...:punchballs:
turbov6
i got a 4.0 out of an explorer and i got a turbo off of a 99 f350 im in the process of getting the rest of the parts now. i got a 5 spd trans out of the explorer also. anybody now anything about a conversion?
auto to man.
