Topic: Does this make any sense? (Read 980 times) previous topic - next topic
Quote from: oldraven;235427
http://www.leftlanenews.com/faulty-chinese-tire-valve-could-spark-recall-of-30-million-tires.html
They're recalling 30M tires because of a shiznitty Valve stem? Using this logic, should they recall the wheels too?
No but maybe the lug nuts... Would make as much sense...
I suspect it's poor research on the writers part(so what's new?), they will no doubt be looking for the valves, can't see that tires have anything to do with the problem...
Yeah, I saw that article and was wondering the same thing...
How would you recall valve stems? Would you know the difference?
If your valve stem comes apart and you go off the road and die, you've got a faulty one :hick:
