Topic: 1993 cougar wont go into drive+no B. lites (Read 1285 times) previous topic - next topic
shift lever {automatic}wont go into drive and brake lights not working,removed switch on pedal and readusted worked for a month now bad again,ordered new switch,waiting on part,is there anything else that would cause this problem?Isaw a vacume switch up there also ,pedal actuated,what the hell is that? not in haynes manual
thanks:toilet:
Nope that's it,if you have no signal from the switch then you have no park release at the shifter.
Quote from: leclerc50@verizon.net;235384
thanks:toilet:
Arnald might be your leader over there but I never thought his speaking ability rubbed off so easy.
The vac switch you located is likely your auto emergency brake release.  Set your emergency brake while the car is off.  Start your car and then put the transmission in gear.  The emergency brake should retract on its own if your car is equipped with this feature.
He has a 93 cougar, unless he fudged the title... The 93 cougars have a aod just like the older foxes if I'm not mistaken... I dont think they have an auto relese on the brake...
about Arnold
:hick: :flame: "California Governor Arnold Schwarzenegger's popularity has been slipping in recent months as residents slowly begin to realize they elected Arnold Schwarzenegger to be their governor
thanks:toilet:
Vacuum dump valve for the cruise control.
