Topic: Need Help Asap!!!!! (Read 1423 times) previous topic - next topic
Need Help Asap!!!!!
Doing motor mounts
I just dropped all the exaust out of the why and pulled the headers but I cant get a socket over the top of the bolt. So i cant tell what size wrench I need to get.
Only guesses I can come up with are 20 or 21 mm or 13/16. I cant tell for sure.
Do i jack it up on the front oil pan sump or the rear sump? Really dont want to screw that up.
ANY HELP IS GOOD HELP!!!!!!
Need Help Asap!!!!!
You don't have to take the headers off, just unbolt the engine mount from the car (that long 5" bolt) and than take off the two bolts that goto the engine block. Jack up the motor a little bit to get the whole mount assy out.
Need Help Asap!!!!!
! Well could I jack it up and slip them in now?
Need Help Asap!!!!!
Ya u will need to jack the motor up put a thick piece of wood in between your jack or else u will crush the oil pan.
Need Help Asap!!!!!
Quote from: cougar86_89;235219
Doing motor mounts
Pretty sure it's 7/8
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Need Help Asap!!!!!
hey sorry, i didnt get your pm until now. I hate working saturdays. I replaced the rubber after the motor was already out of the car then just put the bolt that goes through the middle in when it was in line.
Need Help Asap!!!!!
took about 10.5 11 hours total. from start to finish but I was gone for about an hour to get food, wire and shrink wrap. I screwed up my O2 sensor wires when i did my duals so i had to re do the extensions.
Bob thanks again it helped and Haystack too. Didnt think i did too bad for having no idea what I was really doing.
 AND GOT MY CAR BACK!!!!
Need Help Asap!!!!!
Soo,..... the y pipe HAD to come off???? I broke a mount yesterday,....drivers side,... whenever i hit the gas the whole drivers side of the motor tilts upward towards the hood.....my y-pipe  to manifold bolts are soo rusted,... there isnt a nut shape left to them,... there more "round".....ugh...i hope this goes well tonight......
Thanks for anymore info ya guys can dish out,......
[/IMG]
Just enjoyin the ride!!!!
Need Help Asap!!!!!
No need to remove any of the exhaust.  You can unbolt the mount from the engine and the K-member, jack the engine up a bit, and pull the entire mount out.
