Topic: aod to c4 swap (Read 2780 times) previous topic - next topic
aod to c4 swap
hi
i have a 86 tbird with a bad tranny. i`m going to replace it with a good working c4 for now. i have checked the difference and they are the same lenght.
I have to flip around the crossmember but what else do i need to watch out for?
Willl the speedom.wire fit?
Thor
aod to c4 swap
have to customize the member, i'm doing the same, tried flipping...believe the cable will work,shift linkages might be a lil off
aod to c4 swap
what do you have to mod. i got double hump crossmember,
it sure looked it would just flip over and fit, but i could be wrong:hick:
aod to c4 swap
It's Still A Lil Off, The C4 Bolts Are A Lil Wider, I Took A Piece Of Thick Steel And Drilled Holes And Bolted It Down, Exhaust And Stuff Didn't Line Up By Flipping.
aod to c4 swap
where do you hook up the vacum for the c4 modulator?
aod to c4 swap
Don't you have to have a new flywheel and torque converter?
aod to c4 swap
i got a panfill c4 with converter, and i have to double check but i think it will fit the 164 tooth flywheel.  the c4 got the big bell from what i`ve learned from the net. i hope to get the tranny in tomorrow. I have to mod the crossmember, think i can move the bushings backward to get the crossmember forward. i think hehe :hick:
aod to c4 swap
Quote from: woody76;236020
secondary vacume.Are you running a carb?
aod to c4 swap
nope, but last time i had this transmision working it was ona carb. engine. i thought it needed to be connected to some sort of vacum port. Do i not need to with the efi. (ho conversion)
aod to c4 swap
A C4 ALWAYS needs the vacuum hook up, connect it to the vac tree on the firewall...
aod to c4 swap
Quote from: TurboCoupe50;236072
x2,, too easy.
aod to c4 swap
well, i got the trans in and prop shaft in. Every thing bolted in except i had to mod the crossmember a little. Now i just have to shifter and oil lines hooked up and add some fluids. Any tip how to get the kick down to function right, i`ll get it to work but i`m sure some one has done this swap before with great resault.
i hope to get the aod rebuilt this winter because the gas is like 8,5 $ pr gallon here in norway!! :beatyoass:
Thor
aod to c4 swap
The kickdown basically only operates at full throttle... Not really needed on the C4...
aod to c4 swap
hi.
The car is now runnig again. the swap was a relatively easy swap. worst part was getting the engine/trans bolts bolted up. It was not much room to turn the tools there :beatyoass: :beatyoass:
Had to bypass the neutral switch (easy)
The car feels different to drive, i dont know why but it fells quicker and lighter.
It is fun to drive my T-Bird again :burnout:
Thor
