Topic: Early Mustang GT Scoop on 83-86 Tbird (Read 2262 times) previous topic - next topic
I have heard that you can mount a 1979-82 Mustang GT hood scoop on a thunderbird and it fits and looks good. I have only been able to find 1 picture of this modification and it was not that clear. Has anybody done this or have pictures?
Thanks,
Camertbird
1986 Thunderbird élan
Best ET 14.62 @ 94.20 mph
306ci HO, full length 1 5/8” headers w/2.5” dual Flowmaster exhaust, 8.8” Turbo Coupe rear axle, 3.73 gears, AOD transmission w/Bowman Electronics shift kit, B&M ProStick shifter, 16x8 American Racing wheels on 225/50 R16 tires, Mach 1 hood scoop
Hey another ontario guy,welcome.
1wldbrd did it to his at one point amongst various other scoops.
Not really my thing(stick with a turbo coupe hood)but too each his own,it definetley does fit though.
Thanks, that helps. I looked at 1wldbrd's car. Would still be intrested to see a 83-86 body style with that scoop.
Camertbird
welcome man, cant help ya with that body style, unless you wanna see an 85 cougar with the 85 tbird front clip and a 69 Mach 1 scoop....
Here ya go...:burnout:  was originally on my '86 Cougar, to clear the carb on the 351W.
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Say, where did that Bird come from? :)
Quote from: cougarman;235037
you could have at least put it on the right direction.... '79-'82, opening faces forwards...  '83-'84 it is a different scoop and faces backwards....
if you wanted it facing that way, why didnt you use an '83 GT scoop?
Quote from: Ether947;235050
My son's old 'Bird, long since gone.
Didn't like forward facing "nonfunctional scoops", had it laying around from an old Mustang. I liked it, all that matters to me.:shakeass:
ok... explain something to me.....  how would it NOT be functional if it was facing forwards to "clear the carb..."  with that statement, obviously there is a hole cut out from under it...  so if it was facing forwards, ti would infact be very functional....:mullet:
I thought they had fake openings in them.No real air intake.
Quote from: vinnietbird;235124
Exactly. :hick:
you guys ever hear of a cut off wheel?  the scoops are fiberglass.. VERY easy to open the cover up....
Look, I don't want to argue about the "proper" way to mount a frikken hood scoop. I liked it that way, if you don't too bad. Next time I change something on my cars, I'll check with you first, so it's done correctly. Just so you rest easy, that car is long gone, backwards scoop and all. :toilet:
Why did the bird get sent to the JY.
hahah relax buddy......
