Topic: Who here runs an AOD with 3.73 gears? (Read 2270 times) previous topic - next topic
If you run this combo in your ride, what kind of RPM's are you turning at 65 MPH?  How about 55 MPH also?  Thanks in advance guys.
William
I did till I swaped to a t5, in od at 70 it was 2600 about 2800 in 3rd, not sure how accurate my speedo was though.
With 205/70 tires....ummm....like 2600 @ 80 mph, 2100 maybe 2200 @ 70. I got the digi-dash so its in increments of 200 rpm so yeah best guess ya know lol but I honestly dont know exactly what it is at 60/65, as you can probably imagine by the figures I gave Im terrible out there hahahhaha
http://www.f-body.org/gears/
Standard AOD ratios:
1st:  2.4
2nd:  1.48
3rd:  1.0
4th:  0.67
60mph in OD was just a hair over 2000rpm.
my speedo is about 5-6 mph off but it should be around 2000 at 60 or so.
Thanks guys
That's just the info I needed.  :D
William
Quote from: Sick88Tbird;234381
Your sig says you're running a 2.73:1 rear gear.  :dunno:
William
I'm all screwed up now.  Some guys are saying they're turning around 2000 RPM's and some are saying they're turning around 2600 at 60-65 mph.  :giggle:
William
Quote from: V8Demon;234362
1st:  2.4
2nd:  1.48
3rd:  1.0
4th:  0.67
I tried that site, but for some reason, it won't do the calculation for me.  :punchballs:
William
If I went with a direct-drive AOD (lock-up), that calculator says I'd be turning about 2000 RPM's at 65 mph.  Since I'll probably go with a non direct-drive converter, I'll probably be turning around 2100-2200 RPM's at 65 mph when you factor in the slippage of the converter.  That's still not bad.  I'll just have to make sure I have a properly sized tranny cooler.
William
