Topic: Need Help With Pullie Setup..plz (Read 1851 times) previous topic - next topic
Have a older 302 but have a belt tensioner and pullies from 88, is there diagrams on how this works ,or how the setup is done? im lost and could use alot of help,, thanks guys for any pics or help.. PICS would be great!!  ty
Re: Need Help With Pullie Setup..plz
do you have a Haynes or Chilton Manual? if not i'll try to get some pics scanned and uploaded.
neither.. have nothing to go off of.. any help.. thnx
there yah go! make sure you save that to your system. i have a bad habit of moving things around on my server. ^_^
thanks bud
Does your older 302's water pump rotate in the same way as the newer styles?
If not then you would have to route the belt differently.
Serpentine belts rotate the water pump counter-clockwise.
V-belts rotate the water pump clockwise.
Crankshaft moves in a clockwise motion.
Reverse rotation waterpump.My engine is a '69 with all of the '88 accessories on it.
thanks guys for all your help,, motor running sweet
