Topic: 1.7 on HO Conversion? (Read 5207 times) previous topic - next topic
can you run E6 heads on a SO flat-top bottom end with a H.O. cam (this is the kicker) and 1.7 rollers rockers?
im getting in on of those moods(i get these from time to time but never have the time to do anything) where im seriously considering doing the swap and theres a week coming up where i can probably get off, so im seriously considering taking off and doing the swap then.
but my SO motor currently has 1.7 RR on there right now, and i'd rather not swap back to stamped steel 1.6's if i can get away with it. so will i have the clearance?
1988 Thunderbird sport
2004 Ford F150 Lariat
2008  Chevrolet Cobalt Sport
1988 Thunderbird LX - sold
I'd say yes with the stock H.O cam.
Always check PTV, but you SHOULD be fine.
Quote from: V8Demon;233778
i know it should be checked, but im really trying to not pull the heads if i can. it'd just be easier to do it with the exhaust all bolted up and not having to buy new head gaskets, if im gonna go that far ill put E7's on, which im not gonna go outta my way to do. i cant afford to run into any problems with this, the less i take off, the less chance i break something.
the second method here is how you'd want to do it then
Don't bother checking ptv.
Guys are running bigger cams with 1.7s on so flatops.
Your lift with 1.7s on the stock ho cam will be .477, the e-cam is .499 and the stage 1 TF is .499/.510,guys have run these cams with no problems or ptv interference.
1WLDBRD and vinnetbird come to mind amongst many others.
Yep,my E303 is really happy.
I ran 1.7s on a otherwise stock E6 headed '86 HO, no prob...
@vinnietbird---so you are running the e-cam w/1.7's and E7's on SO flat tops?, no releifs?
That's .529 lift,,,,,,,,,that's cool
Vin, what springs do you run?
No vin runs 1.6s on his.
It's amazing how quickly people forget that the SO motor does NOT have flat top pistons...it's dished with no reliefs.
Quote from: dominator;233792
sweet thats what i wanted to hear. i should be good to go then.
Quote from: Sick88Tbird;233901
sorry, its easier to say flat-top then dished with no reliefs. apologies all around.
They are flatter than HO pistons. ;)
It's become quite common over the years to say that here though; even though it is technically incorrect.
Stop getting hung up on the max lift #'s.  They have almost zero effect on piston to valve clearance.  Where is the piston when the intake lobe is at full lift?  Where is it when the exhaust lobe is at full lift?
Quote from: TurboCoupe50;233820
did you clay yours? if you got away with it, i should be able to also correct? idk how close im cutting it with the graphs stated in the previous post.
