Topic: In the dark. (Read 1100 times) previous topic - next topic
In the dark.
I finally got tired of using a Bic lighter for a dome light, so I bought one from a Taurus. I have two wires hanging from the headliner(blk/blu& lt.grn/yellow). The taurus light has three wires(grn/org, blk/blu,& blk). Anyone have a clue on how I make this work?
In the dark.
LG/Y wire is for the map lights. It is hot at all times.
BK/LB is for the dome light. It is hot when the doors open.
Ground is apparently through the mounting screws.
Don't know what the story is on the Taurus light. Maybe it has a ground wire? Can you check it out with an OHM meter?
In the dark.
If your dome light is from a mid 90's Taurus then the Green/Orange is +12volts hot, black/blue is dome, black is ground. Hope this helps
In the dark.
Thanks guys. I,m going to try to hook it up this afternoon. I'll let you know the results.
