Topic: compression ratios... (Read 1458 times) previous topic - next topic
i googled it up, and could find jack schit on what i was looking for
whats the compression ratio for an SO 5.0 with E6 heads, and the compression ratio for an HO with E7 heads?
Re: compression ratios...
The '86 HO was 9.2, don't see why it would be any different for a SO... '87-up HO is 9.0, the .2 drop is because of the valve relifs in the later pistons, as both HO and SO heads have a 64-65cc chamber.
Hot Rod magazine Feb'87 states 8.9:1 compression ratio for 87 Tbird Sport in a comparison article vs Turbo Coupe. I read too much!
87 Sport with HO cam, 19# injectors,TB+Upper Intake,87 Mustang EEC, Cloyes double roller timing chain, Kirban adj. fuel regulator and Autometer fuel pres. guage, HO shorty headers + LSC H-pipe and Dynomax Super Turbo lers, Ford Racing 9mm wires, K&N filter / no air resonator, 8.8 XR7 Diff., V rated tires, Project ongoing.
