Topic: Strut bushings (Read 6600 times) previous topic - next topic
Strut bushings
what is the websites for the aftermarket tbird strut mounts?
Strut bushings
Quote from: Cougar5.0;232986
I had decided after this post that just getting CC plates was best. I had a nice set of MM chrome CC plates for our cars in the cart at JD'S Performance ($236 including shipping), but then I did more research & several people with MM plates were complaining that certain struts had a "thinner" shaft and made horrific noise. If the tolerance of the strut shaft is going to be an issue - especially the struts I was most interested in (Strange adjustable), then I think I will stick with the stock mount and deal with the lack of caster for now.
I got the MM c/c tbird cougar plates with the strange adjustable struts, I just installed them last week but didn't drive yet what did you need to know?
Strut bushings
Several people complained that the struts click in the mounts because they said the strut shaft didn't fit snugly in the CC plate bearing. I didn't want to chance it.
Strut bushings
oh really... well I hope they don't LOL It would just drive me nuts. I'll let you know.
Strut bushings
so is this the aftermarket strut mounts that will work to be able to use mustang strut bushings on our cougars or thunderbirds? here is a link to them http://cgi.ebay.com/ebaymotors/Parts-Accessories_Car-Truck-Parts-Accessories__2-STRUT-MOUNT-MOOG-THUNDERBIRD-CONTINENTAL-80-92-FRONT_W0QQitemZ130275881270QQddnZPartsQ20Q26Q20AccessoriesQQadiZ2865QQddiZ2811QQadnZCarQ20Q26Q20TruckQ20PartsQ20Q26Q20AccessoriesQQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item130275881270&_trksid=p4506.c0.m245&_trkparms=72%3A543|65%3A12|39%3A1|240%3A1318
Strut bushings
Cougar5.0,
Why did you want to go with Strange?  Something wrong with Koni, Tokico, or even (heaven forbid) Bilstein?
IF there isn't a solid fit, you'll get horrible sounds from the front end. And then something will probably break, and then the horrible sounds will be even worse.
__________________
Twin '85 TCs
White/ Grey 2-tone
Strut bushings
I put together a comparision chart of all the popular struts available with the intent of finding the best street/strip strut available. In the plot below, you can see that the Strange has the widest available adjustment range (excepting perhaps the Tokico D-Spec) which was key as I needed a strut that could be adjusted soft enough to allow me to launch with the stiff Mach1 (600#/in) springs in the front. Since the D-Specs were not only a lot more money, but had some complaints of the adjustment screw turning on it's own, I decided to go with the Strange 10-ways. I'm very happy with the result. They ride nice on the street & can handle the stiff springs, yet they go soft enough to allow weight transfer which can be difficult with a short, stiff spring in the front. They may not have the finesse of a Bilstein or the autocross handling of a Koni Yellow, but they are an excellent all-around street/strip performer with a seemingly good reliability record.
Strut bushings
That sucks they didn't fit properly.  I've had a few Konis, never had an issue with installation.
__________________
Twin '85 TCs
White/ Grey 2-tone
Strut bushings
I had no issues with installation because I used the same mounts as in the Ebay ad below:
So the answer is - yes, those are the right mounts.
OEM Cougar Strut Mounts
Reply #39
88 Cougar XR-7. If I remember correctly, the strut mounts they sell at pep boys don't look like the OEM mounts which had the bushings molded in as one piece I think.  I've been having a problem with noise when turning.  I replaced my struts and mounts with just direct replacement parts from pep boys.  Gabriel Struts.  I tried lubricating and reinstalling the mounts, but no luck.  Can I buy the OEM type mount somewhere or am I just imagining that they are different.  Does anyone have a picture of the original equipment mount?  Its been awhile and I threw mine away.
Strut bushings
Reply #40
Quote from: Cougar5.0;256033
Man, that is a great chart, but what the hell is it showing me? LOL
Tell me how to read which shock is best for me.
Mike
