Topic: Strut bushings (Read 6597 times) previous topic - next topic
Strut bushings
Buy the TBird strut mounts....  Moog or TRW make them.
Strut bushings
OK :hick:
Strut bushings
Good Lord.I drug that all over the place.LOL.Thanks Chuck.
Strut bushings
That's OK - I leached onto this - 2 birds, 1 stone :D
(actually 1 bird, 1 cat with 1 stone :hick: )
Strut bushings
So,we're good?Right?
Strut bushings
psst Vinnie,
CC plates would solve your problem too.
__________________
Twin '85 TCs
White/ Grey 2-tone
Strut bushings
I'd love to,but with the new rear bushings from Energy,the whole T-5 swap,the strut tower brace,new B&M shifter and other parts,they'll have to wait.I'll probably end up with a set eventually.Right now,I'm waiting for more funds.I still need the front a-arm and strut bushings,ball jints,and I also have to pick up my fenders and other parts this week.Man,there's a lot going on right now.
Strut bushings
I had decided after this post that just getting CC plates was best. I had a nice set of MM chrome CC plates for our cars in the cart at JD'S Performance ($236 including shipping), but then I did more research & several people with MM plates were complaining that certain struts had a "thinner" shaft and made horrific noise. If the tolerance of the strut shaft is going to be an issue - especially the struts I was most interested in (Strange adjustable), then I think I will stick with the stock mount and deal with the lack of caster for now.
Strut bushings
so who sells the aftermarket tbird strut mount that look like the mustang ones?
Strut bushings
Quote from: blackcougar71;255637
Moog, TRW....  Most parts houses will be able to get them.
Strut bushings
I went to Autozone a couple of months ago and bought new strut mounts.I have yet to install them.I'm waiting to replace the strut mounts,springs,lower a frames (Thanks chuck),and ball joints all at once.I don't want to tear into this twice.
Strut bushings
Cougar5.0,
I didn't see your last post until now.
Do you remember which struts were experiencing/causing problems?  I've had cc plates on two different Konis and didn't have a problem.
__________________
Twin '85 TCs
White/ Grey 2-tone
Strut bushings
The strut I mentioned (Strange) was the one most likely to read complaints about the play between the strut shaft and CC plate. I ended up with aftermarket replacement mount with the Strange struts as I needed the flexibility they offer for street/strip. So far, so good as my 60' was not affected by the stiffer Mach1 springs using the adj. strut to compensate.
Strut bushings
ok , im putting the 11" inch turbo coupe barkes on my 88 tbird v6, what struts do i use because the factory ones wont work
88 thunderbird, 306 ,E7 heads ported by me, explorer intake, 70mm professional products TB, 8.8 3.73 rear is finally in. 11" front brake upgrade. still need some stuff
some nice weather to work on stuff would be nice ^^^
Strut bushings
The factory struts are fine,just uses spacers between the strut and spindle.Also,you'll probably need a new master cylinder for the bigger brakes.I'm not sure about the proportioning valve..
