Topic: Strange problem. (Read 1266 times) previous topic - next topic
Strange problem.
Could this be ign. switch related?At times my car won't go over 3000 rpm kinda carrys on but won't go past it.If I shut the car off and restart it it's fine.it does this hot or cold.but only once in a while.I have no codes except fuel pump and egr and I know about them.This wasn't noticable untill I installed the t-5.I switched computers A9p to A9l and back again both do it.
Anybody ever run in to this?I'm going out shotly to check some things.
Strange problem.
Wil the car not accerate (under load) or free rev out of gear??
Strange problem.
It's alot more noticable in gear.It's not real smooth out of gear either but will go over the 3000 rpm.Of course today it won't do it.
Strange problem.
May be fixed,I had an open breather on the valve cover,made it closed system again.also hooked the vss wires to the computer.
So far no problems.
Strange problem.
How do you hook th VSS wires up?
Strange problem.
Vinnie,88's should already be wired.
Strange problem.
Then I'll consider the job done.LOL.
Strange problem.
If you look at your comp.plug,#3 + #6 should have wires in it.
Strange problem.
I'll bet you're right.I am now having memories of that from the Mass Air upgrade.
