Topic: Suggestions before reassembly? (Read 1673 times) previous topic - next topic
I'm looking for suggestions and ideas before putting the interior back together.
I've got RAAM insulation to add, some replacements for worn or broken parts, everything's getting cleaned or new paint, incandescents replaced with LEDs.  I'm thinking about having the headliner done again even though it looks good now.
While everything's apart, is there something not mentioned that should be done or replaced?
__________________
Twin '85 TCs
White/ Grey 2-tone
Do you already have new carpet?If not,get some.No need cleaning old carpet when new stuff is fairly reasonable.
Forgot to mention the carpet.  Got it after trying to clean the original.
__________________
Twin '85 TCs
White/ Grey 2-tone
Quote from: t3skidoo;232351
What's RAAM insulation?
http://www.raamaudio.com/
__________________
Twin '85 TCs
White/ Grey 2-tone
That stuff looks nice, how is it so far?
Not far enough along to tell you anything useful, but will post when I know something either way.
__________________
Twin '85 TCs
White/ Grey 2-tone
I have parts,tools,space to work,most everything i need.I just can't find any time.
I would check the dash cover and shifter boot, and the covers were the power seats if u have them. Check that stuff.
My opinion on the RAAMmat BXT/any decent mass-loaded dampener and closed cell foam, I didn't gain much doing the sides of the car. The doors are dead silent down low, but all I hear is wind noise at the top of the doors. I did numerous layers of RAAMmat BXT over the entire sides of the car with a single layer under the rear seat, with 4.5 layers of their closed cell foam on the doors (2.5 on the inner metal, 2 on the outer) with not enough improvement for the amount I put on. The roof and floor would gain the most after hearing my differences doing the walls. I'll get around do adding to these places at some point down the road but I don't haver an issue with road noise as the factory stuff is THICK and does do quite a good job.
The roof needs help and the door to roofdesign can't be fixed - the huge channel between the door top and roof causes terrible wind noise at highway speeds where I wanted the deadening the most.
Also, don't put too much deadening under the rear seat...it won't go back on. I completely bent my lower seat when trying to push the first side into its little groove.
I doubt you spent hundreds on deadening materials though so I don't think you'll have the same problems I ran into. The door design itself was still my biggest problem with front stage sound quality - they just aren't setup with the proper angles or structure that can lead to good sound. I put mass loading on all internal parts, along with foam and things still rattle inside there just driving down the road. It drove me insane but I just gave up the quest for silent doors. Too many rods and a poor door handle rod design (bolted tight, it still rattles until you put 50lbs of weight on the handle itself, then it stops). Who knows, it may just be my doors.
1988 Thunderbird Sport
88TurboCoupeman01,
I've got a new dash cover, and have reconditioned the shifter boot.
Vinnie,
I've got time, money, or space.  But only one at a time, and never enough of any.
Seek,
Thanks for the info.  I've been wondering what, where, and how much to add.  Have you had your headliner out of the car?  If so, what would you change about the insulation? Did you cover the access holes in the doors with anything?
__________________
Twin '85 TCs
White/ Grey 2-tone
