Topic: 70mm Mass Air meter/sensor (Read 1201 times) previous topic - next topic
As the title stated,70mm Mass Air meter/sensor  $35.00 shipped.
for what year?
It's always fun until someone loses an eye. then it's fun ya can't see.
-James Hetfield back when metallica was still making good music.
It's identical to the one I'm using on my '88 with Mass Air,5.0 H.O. with mods (see my signature below).If you do the Mass Air conversion on one of our V-8 cars,you should be good to go.
i know you're all about the fox, but what would this do for my mn12?
Probly nothing since the MN12's are larger then that from the factory LOL.:D
I take it this was off a 93' Cobra Vin?
1988 Cougar LS 5.0 (currently parting out):cougarsmily:
1989 Mustang LX Notch 2.3 (Project):ford:
Same size,different sensor than a Cobra.Cobras had 24# injectors,this is for 19#.
Vinnie...I'm interested in your meter. Can you tell me the part # on the sensor?  Do you know if this meter works ok?
1988 Thunderbird
306 HO w/ A9P processor
AOD w/ Transgo Reprogrammer
245/50/16 Tires on Snowflakes
It worked fine when i pulled it a few weeks ago.I bought it from a member here last year..I took it off my car and installed another that I polished up.
Just a tip but if you use a 70mm MAF housing from a 94-95 Mustang, 92-95 Crown Vic, Grand Marq, Town Car, or the housing from a 94-95 T-bird/93 Cobra you need to use the MAF electronics with a F2VF part number. If you swap in the stock 55mm MAF electronics you will run lean because the sensor is not compensating for the 70mm diameter. Lean=not good.
This sensor came with the meter,not a problem in the Sport.
Vinnie...I sent you a PM
1988 Thunderbird
Got it.
Quote from: vinnietbird;233303
Then you should be fine ;)
Soooooooooold !!!!!!!
