Topic: Distributor question! (Read 933 times) previous topic - next topic
Hi, my question was where do i loosen the distributor so i can adjust the timing? my car is a 87' cougar Ls 5.0... i tried looking around it but there is no bolt/nut that is visible. thanks in advance
LOOK again.It's there.
Look where the distributor should sit. There is alittle chunk that flairs out. There should be a bolt there. There usually pretty well covered in oil and grime...
Ok, im gonna go check again right now
A 1/2 inch socket or end wrench should do it.
right on, i found it and set my timing.... thanks for your help guys
Quote from: Haystack;231717
Errr Haystack, you're over doing it just for a timing adj...:rollin:
