Topic: Sensor hole? (Read 1065 times) previous topic - next topic
Sensor hole?
Use to be a 302, but now swapping in 351.  GT40 lower.
There is a hole in the intake behind the throttle body.  I can't find any info on what should go there, but I'm thinking a sensor.....which one, don't know.  Any help would be appreciated.
351W in the works
Quote from: bhazard;300566
You got woman'd.
Sensor hole?
are you talking about the EGR port? you would have to remove the throttle body to see it.
1979 Ford Fairmont
[/B]
Sensor hole?
I don't know, thats why I'm here. :D
You'd have to take off more that the throttle body for this.  The heater core lines block it too.
Here are some pics with the hole circled.
351W in the works
You got woman'd.
Sensor hole?
Thats for the water line for the egr spacer.
Sensor hole?
But,that's not a GT40 lower.
Sensor hole?
Quote from: vinnietbird;231367
Yeah, the GT40 is on the engine, and I couldnt get a good picture. Thats the stocker.  Same size and place.
Would it make a difference?
351W in the works
You got woman'd.
Sensor hole?
I blocked mine off, than you need to plug up the port on the black coolant hard line also.
Sensor hole?
I plugged my water lines to the throttlebody spacer as well.I have never been able to tell a difference.
