Topic: what about the stock ho cam in a so? (Read 2263 times) previous topic - next topic
i know the fireing order would be different...but would the ho cam work in the so with stock heads or would it just suck ballz? mostly curious. i doubt id go through the trouble of a camswap without getting at least som e7 heads.
and what about the cam bearings...weather i used a used cam or a new cam...i guess people swap cams without new bearings...
~John~
Re: what about the stock ho cam in a so?
The '86 HO used the E6SE heads and was rated at 200hp, also it had a SO intake and smaller throttle body(58mm) than the '87-'93.
My stock '86 5 speed Stang would run mid 14s all day long. OK it did have a 2 1/2" cat back system(14.58@94), and I added the 1.7 roller rockers and under drives(14.51@95.5). The rockers and pulleys picked it up more than the ET would indicate, had severe traction issues.
did the 86 HO get pretty much the same cam as the 87-93? i know the cams varied a bit through the years, but were still very similar
The earlier cams were actually better from what I've heard, specifically the 87 and 88's.  I found an article online about it a while ago that had the exact specs. Can't seem to find it today. I DID find this:http://home.pon.net/hunnicutt/history_79_93.htm
http://www.50tech.com/forums/viewtopic.php?t=4636&highlight=stock+cam+differences+yeay
i should have thought of that...so their would be no clearance issues? im mostly interested in getting the engine too pull past 4600rpm. sick of driving the car like a truck and i only have 200 miles on it this year.
~John~
Flat tops with no reliefs,  ported e7's and about .480 lift here with 1.7 roller rockers.  No clearance issues.
what about cam bearings. im thinking you cant change out the rear ones while the engine is in the car. safe to reuse the bearings? even on a used cam? i figure ill mess around with this engine for now bot i dont want to go out of my way to wreck it...
~John~
Never heard of cam bearings being a problem, even on used bearings and cam. As far as I know about the only time they are replaced is during a rebuild...
If you want that 5.0 to rev, you'll need some better valve springs. Even the HO springs are about like mush, my '86 HO would only pull to about 5200 before it went soft...
the stock 14# injectors wont work with the new fireing order cam and computer right?
~John~
Quote from: shame302
Nooope..
They'll work just not correctly :D
I'll be doing the change as soon as I get my cam in the mail. So I'll let ya know how it goes for me.
awesome. i appreciate it.
~John~
Hey shame302, did you have to change your throttle cable to put on the h.o upper intake? Mine's too short and it won't reach.
