Topic: Keys Lost... Column Shifter (Read 1096 times) previous topic - next topic
Hi all,
We are trying to move one last car that won't run...
What's the best way to bypass the lockout on the column shifter so you don't need the key to put the car in neutral?
Operation: X Marks the Spot
5.0L SEFI, AOD, 8.8" 3.02 TracLok - All Stock
disconnect one of the linkages under the car, and move the lever on the side of the trans to neutral.
1979 Ford Fairmont
[/B]
Thanks 32VFoxBird
I was hoping to see if there was a way to disconnect the lockout right on the column, but no biggie, I ended up doing exactly what you'd suggested.
Then we find the keys :hick:
LOL
