Topic: My car...a couple of new pics. (Read 38269 times) previous topic - next topic
Reply #165
Just make sure you only have 1-2 gallons in the tank when you change the pump. I did mine with half a tank. Not fun
Been there, done that.  The car is on its 3rd fuel pump.  I changed it once with over 1/2 and it sucked ballz.
Reply #166
Got another update on the car:
The intake is on along with the bbk h-pipe.  It should be ready to fire tomorrow, but the py thing is I have to work all day tomorrow.  So my pal is going to try and finish it up without me.  I feel horrible for not being around but thats part of it.  I have to pay for this habit somehow!
We found out that with column shift, the o2 sensorshiznit the shifter linkage.  d'oh, I should have thought of that!!  I bought one new o2 sensor with longer wires on it because we f'ed one up trying to get it out of the old manifolds. I am thinking when I take it to the exhaust shop, I will have them weld up the old bung and place the o2 sensor a bit further down and away from my shifter linkage.  We may even end up splicing more wire into the o2 sensors to make them reach even further back.
Another question...since I deleted the smog pump there are some leftover doodads that I am not sure what to do with.  For instance see below.  What exactly is this vaccum "port" for?  I remember there being vac lines going into it and maybe one going to the charcoal canister ??
Speaking of the charcoal canister...can a guy just delete it too without the car reeking?  Anyone on here deleted theirs?  I figure it is on there for a reason.
Reply #167
I have deleted the charcoal canister and associated vacuum lines with no issues I can discern.  Sorry, can't tell what the lines you have indicated are.
Reply #168
Quote from: 86T-bird;269053
OK cool.  I may just delete it then.
Reply #169
Mine still has the charcoal canister and EGR but the Thermactor stuff is all gone. What I did was just follow the vac hoses and join/cap them off where they needed to be to keep everything functional and the engine happy ;)
Reply #170
So ya get it fired up today??????? Id imagine youre out enjoying it!!!! Let me know if it rips!!!!!!!!!!!!!!
[/IMG]
Just enjoyin the ride!!!!
Reply #171
Quote from: 50tbrd88;269057
I belive paul is looking for those parts.
Reply #172
I have now driven a 5.0 HO T-bird.  We buttoned everything up around 3:30 yesterday and I drove it about 4 miles back to my place.  I couldn't really get on it too much because I am running straight pipes right now (headers and h-pipe) but initial thoughts are that the car will be much faster.  Even just taking off and getting up to speed I was running 70 mph without even realizing it.  And that odd vibration I had been trying to diagnose for over a year?  Now I know that that was the motor mounts because it is gone!  Right now the car basically sounds about like a demo derby car or something.  I had a headache from just driving it home.  lol.
It will go to the exhaust shop hopefully this week and get lers and tailpipes put on.  I am also going to have to have them move my 02 sensor on the drivers side out of the way of the shifter linkage.  One other problem that cropped up:  The drain plug was and oversized plug but it never leaked since I put it in a couple of oil changes ago, now it leaks like a mother.  Like a pint or two just over night.  I am going to try to put a different plug in but I may have to resort to something more extreme down the road.  I should have just put a new pan on it while I had it out...
The only other problem is that the sensor thingy on the throttle body (what's it called like a ATC or ITC or something??) is going bad.  I am going to work on it some today I'll get some pics posted later.
Reply #173
Quote from: 50tbrd88;269154
TPS???? yeah i got a new one too, they arent that much, and only two screws and a clip....You must have been turnin some heads while drivin that beast around!!!!!!!
[/IMG]
Reply #174
IAC idle air controller. oilpans suck in the car.
Reply #175
yeah IAC thats right.  Never can remember the name of that doohickey.
So I worked on the oil pan situation.  What really  me off is that it didn't leak a drop before this and now that we've had the motor out and back in it has decided to be a prick and leak.  I went and got an oversized plug today and tried to use it but it totally screwed the threads up.
After checking it out I found at that the threads in the pan are broken.  Don't ask me how this happens but I am definatley going to have to pull the freakin' pan now.  I have decided I have turned enough wrenches on this thing lately...its going to a shop to get done.  Call me a wuss if you want but my wife is about ready to kill me the way it is.  If I spend then next week in the garage I am a dead man!
Here are some pictures of the engine:
Reply #176
You know a striped rear oil pan plug was the whole reason for my engine rebuild ;)
Reply #177
Quote from: thunderjet302;269399
Glad I'm not the only one!!  Its frustrating because I just want to be driving the wheels off this thing right now.
Reply #178
Hopefully you'll get it resolved soon :D I figured it would be easier to pull the engine to change the pan so I figured while it was out I might as well rebuild it :hick:
Oh how's that computer working for you?
Reply #179
So far so good!  I only drove the car 4 miles so far but it worked like a charm.  I actually still have the kick panel and associated trim laying in the floorboard.  I still need to button everything back up.  lol.
I am going to at least try my "drill and tap a patch and then weld on the pan" trick.  Sure its redneck engineering, but I figure its worth a try and might save me a big bill.  If it doesn't work then off to the shop it goes!
