Topic: My car...a couple of new pics. (Read 38306 times) previous topic - next topic
Reply #150
You have to grind the AC bracket down.
Reply #151
That's what scares me...I already have done some grinding on it.  I could probably grind out more if need be.  All I know is, that hood will be closing one way or another.
Reply #152
Headers and the dipstick are problematic.  I've crimped a couple over time resulting in trips to the junk yard.  A brake line tubing bender may help get it routed properly, minimizing the kinks.  It can take a bit of time and be frustrating
Fastening the dipstick to the header bolt can be another challenge.  I haven't ever come up with something than has looked very professional for that...
Glad to hear you are getting close.
Reply #153
I see that now. lol.  At least I have the dipstick tube from the donor motor I could always use if I crimp this one too much.  It definatley will not work the way it is now.  It is VERY hard to pull the dipstick out and I'm afraid it will break.
Reply #154
I got my stock dipstick tube to work with the factory HO headers as well as my FRPP GT40P headers. I just bent it a little by hand and it bolted right up :dunno:
Reply #155
My issues were with couple sets of long tubes and a set of equal length shorties.  It seems with any aftermarket part install, something else has to get tweaked.  Even after all the years I've messed with this stuff, I'm always surprised!  Still a slow learner...
Reply #156
Quote from: 86T-bird;268791
Fastening the dipstick to the header bolt can be another challenge.  I haven't ever come up with something than has looked very professional for that....
I cheat.  I bolt it to the valve cover....
Reply #157
Hey!  I like that!
Reply #158
I may have to cheat on that dipstick deal too.
Should come closer to firing it up tonight.  I plan on running it on stock SO fuel pump for awhile (maybe a week or two)...I don't forsee any issues with this.  Do you guys think it will be OK?
Reply #159
Quote from: 50tbrd88;268831
Should be ok. I am better sure a few people have done it without issue. 1WLDBRD I believe.
Reply #160
Just hold off on the full throttle runs until you get the upgraded fuel pump.  It'll run fine in normal driving.  If you run it hard, you'll know if you max out the fuel volume, it will feel like you slammed on the brakes!
Hope you have good luck getting it running!
Reply #161
Quote from: DVP;268833
Yep, I have been running mine quite hard for over 6 months on the stock 302 pump...  No issues yet.:mullet:
Reply #162
Yeah I've actually never changed my fuel pump.... collar rusted to hell...didnt even want to try yanking it apart. I will at some point...but for two years now all has been well...so I dunno. Again I do need to change it to be safe. Im glad it has been okay though.
Reply #163
I will probably wait awhile and let my bank account recover a bit before I buy any more parts :D.  But, I really have done this swap for pretty reasonably small amount of money.
Reply #164
Just make sure you only have 1-2 gallons in the tank when you change the pump. I did mine with half a tank. Not fun :hick:
