Topic: is this any good (Read 1423 times) previous topic - next topic
is this any good
the controller yes the BOV not for a stock t/c
is this any good
Why pay the cash when you could make your own controller. Then I tell you to look into a Bypass valve instead. IF setup right the BPV will help you keep the turbo spooled up after shift. I know I told someone on here how to make a MBC for like $15. do some digging on the net that is where I found my info. If you run a BOV on a stock setup when the BOV opens it will let metered air out so you'll have a rich spike and I've heard about idle problems. You do what you want though.
is this any good
that would have been me. i spent 8 bucks and have it boosted to 15PSI.  thing is an animal.
in a word?
no.
no.way.
If you want boost, just bypass the BCS with a length of vacuum line, more boost faster.
__________________
Twin '85 TCs
White/ Grey 2-tone
is this any good
 is, by definition, shiznit.
is this any good
what is a bcs  and ive lookked for info to make a boost controler but i haave no luck
is this any good
That bell outlet on that BOV unscrews and you can stick a threaded piece of pipe on there and make it a BPV.
is this any good
What quality of stuff do you think you're getting for a whole $18?  Seriously.
