Topic: 6 speed conversion (Read 2064 times) previous topic - next topic
6 speed conversion
Is there any kind of 6 speed maual transmission that will bolt up to my TC.
6 speed conversion
no
1979 Ford Fairmont
[/B]
6 speed conversion
I believe the T-56 has an integral bellhousing (somebody step in if I'm wrong), so one would need to either find/make an adapter plate and deal with spacing issues or cut the existing bell housing and weld (or otherwise permanently attach) the adapter plate to the amputee.  BTW, I think the T-56 is about 100lb heavier than a T-5.
If you're looking for 6-speed functionality for a stock motor, you might consider the 928 configuration and look into something like this
http://www.quaifeamerica.com/transmissions/trans_main.htm
That would make for kick-ass weight distribution if you're wanting a fleet-footed fox.  (add some inboard brakes to the ensuing IRS to be totally trick)
Of course, it would probably be easier to swap in the engine and trans from a donor.
__________________
Twin '85 TCs
White/ Grey 2-tone
6 speed conversion
If you can graft a Lexus IS,  BMW 3 series, or some similar European sportscar 6 speed manual tranny into the car, I'd love to see it.  Just a bellhousing adapter away... short of making if fit, getting it to shift, stickshift placement, etc...
1987 TC
6 speed conversion
sounds like alot of work compared to a 2.3/SBF adapter plate and a T56 w/5.0 bell....
its already been done, many times over.
6 speed conversion
That's why I'd love to see it, lol.
(think D&D Performance)
1987 TC
6 speed conversion
ive deffinetly seen it done in a tc b4. i love mine but its really not worth the trouble imo.
~John~
6 speed conversion
Quote from: gumby;230614
That's what I was gonna recommend.  Just don't forget to change out the speedo gear, I just put whatever D&D gave me, and almost got a speeding ticket because of it. 90mph in a 70mph isn't a bright idea. :D
pro-five-oh
