Topic: Good deal on Mark rear? (Read 1787 times) previous topic - next topic
Found a guy who has a rear out of a 90 Mark VII. He told me he wants 160 for it.
Is that good?
He still has to pull it so I might tell him Ill pull it if he knocks it down. Then what should I pay for it?
5 lug has really been on my mind lately
Try $100 to 120 if you get it and $160 sounds okay
And I need TC E brake cables right? hope I can find those un froze....
this is the only usefull link i could find
http://www.coolcats.net/tech/advanced/tcaxle.html
Sorry if you allready looked over it all
Quote from: Carpimp1987;229600
There is more on CoolCats than just that in the 4 to 5 lug swap section. I just need to know what all I need to get from the guy off the Mark. He said its trac lock with 3.55!
If its stock its not.
Take the back cables to if there good,thats what most of us are using now.but new ones are fairly cheap.
http://www.foxtbirdcougarforums.com/showthread.php?t=13175
Quote from: bhazard;229606
Not a good deal or not 3.55s? I thought they was suppose to be 3.27
Does it come with brakes?
At some point, the MK7's switched brakes from the old 11.5" SVO ones to the TC-type.
I'm not sure if the track width narrowed at that point, or if there were special brackets, etc.
If you get it, do the board a favor and take a few measurements (namely axle  to axle  and housing width) so the spreadsheet that Jeremy B put together can be updated.
Lincoln width or TC width aside, both will fit under your car just fine.
$150-160 seems fair.
Quote from: Chuck W;229629
Thanks Chuck. Think I am going to get it. I want to be able to swap rims easier (find them cheap easier). Plus anything is better than my 2.73s.
Quote from: cougar86_89;229592
I'm still looking for a pair of the Mark VII hinge springs if he has those available.  ;)
http://www.foxtbirdcougarforums.com/showthread.php?t=19741
Chuck,
It looks like it was the 1991-92 Mark VII's.
According to the Raybestos book, the height of rotors changed in 1991 from 2-3/8" to 2-23/64" and the diameter whent from 11-21/64" to 10-17/32".
Raybestos replacement rotor specs:
TC rotors:
  • Overall Height - 2-21/64"
  • Diameter - 10-11/64"
Mark VII rotors:
  • Overall Height - 2-23/64"
  • Diameter - 10-17/32"
I haven't had physically checked it out yet, but in theory, using the following combination of parts may be a less expensive and fairly route to converting an '87-'88 TC rear to 5-lug while still retaining vented rotors on the rear.
'94-'98 Mustang axles and the '91-'91 Mark VII rotors.
Brent
:cougarsmily:
One of 1,246 built
OK, well that still doesn't answer the question on whether the overall track width changed then as "technically" the rotors are all about the same height (as no thickness is noted).  The change from the SVO-type stuff to the other only nets a 1/64" height difference.
However, since the TC and later Mk7 rotors are about the same height, it's hard to say w/o comparing the axle brackets.
Anyway, the '90 should have the earlier "big" brakes.
i paid 150 for mine but it was out of a TC and had 5lug axles put in it. 3.55's and t-lock
Quote from: 87thunderbirdBlackJack;229851
Did you get your front swapped to 5 lug yet? If not looks like you won't be the only one:mullet:
He hasnt e mailed me back yet but I will check on those hood hinges for you.
Offered him 140 and he said no thanks Ill keep it.
