Topic: will a set of '93 Cobra GT40's (Read 2198 times) previous topic - next topic
Oh ok. E6 heads had about a 67cc chamber didn't they? I could be waaaaay off though :hick:
these are my pistons....
I think I will just sell these heads and build another spare HO that I have laying around...  dunno yet...
Quote from: thunderjet302;229732
Most sources list them @ 68....some list 67....
There is an option to use the larger valve heads w/flat top pistons, if you chose to go with a custom cam.  P/V clearance has more to do with valve timing than lift.  While a custom cam is more expensive than off the shelf, the economics may work out more favorably than selling the heads and building another engine.  Check out Camshaftinnovations.com.
