Topic: Is a GT40 5.0 worth the trouble? (Read 6795 times) previous topic - next topic
Hey guys.  I'm sorry for the newbie question, but is it worth the trouble (performance wise), to go through the trouble of putting a GT40 5.0 in one of our cars, instead of a normal 5.0 H.O engine?  If you get your hands on a H.O. 5.0, you don't have to worry about changing the things you have to change on a GT40 5.0 to get it to work in a Fox chassis car.  I know the GT40 heads flow better than E7's do and the GT40's intake flows better, but like I said, do most of you think the performance improvement, or potential of a GT40 makes it worth the extra work?
Thanks for any and all replies.
Vic
William
you would want to change the cam in the explorer motor.
Quote from: SLEEPER T-BIRD 87;229536
The search function really is a wonderful thing!  By switching around key search words I was using, I brought up a lot of good info on this topic.  I just read that Explorer cams were milder than H.O. cams.  After finding the info I did, it looks like my best bet will be to go the 5.0 H.O. route.  Down the road, I guess I could always tweak my combo.
William
The GT-40 is to the HO what the HO is to the SO...Unported, E7 heads are , go with the 40 and put a little more cam in it...
Quote from: TurboCoupe50;229542
Because of the pistons in the GT-40, aren't you really limited on how much cam you can run without clearance issues?  I was under the impression that PTV clearance was even more of an issue with 40's than with regular HO's.  Do you have any recommendations on a good cam for a 40?  I think I can get my hands on a 40 out of a 98 Explorer.
William
There are GT-40 high performance cams out there just google them or go to your local racing shop and order them. I seen a GT-40 in a factory mustang 5.0 and I drove it too and the cam was like the best cam in the 5.0 mustang motor just get a mustang motor and put a Bigger  lift GT-40 cam and sprap u self and also get rady to wash your drales when u get home cause the first time u drive it the coolest feeling, I neaver driven a 5.0 mustang motor and had a better experance and the best thing is the car got 20t miles in the city with just a GT-40 cam and 3.83 gears. If that doesn't convience u to do this set up than I want to know what your smoken cause so I can stay away LOL.:burnout:
Ummmmmmm......  Huh?
Quote from: 88TurboCoupeman01;229553
My google search is showing me that the "GT-40 cams" you're talking about are regular, old alphabet cams dude?  B303 & E303 cams.  That's what FMS is listing as being used in the GT40 crate motor.  I know I can do better than an alphabet cam.  That's old technology there.
William
Well the guy told me it had a t-40 cam and I could tell it had a cam in it so I don't sorry guys.
Any mild cam should work your pistons have the valve reliefs in them, just check w/us first. When you call they are going to cautiously tell you to always check PtV clearance for the safe side nomatter what. That’s what they told me w/a stock HO motor but then I put on bigger GT40 heads milled .040 off them w/a .039 head gasket. I never checked. Picking my motor/machine shops mind he told me I have plenty of room.
Heres my set up
http://foxtbirdcougarforums.com/showthread.php?t=17223
Get Steeda Cam #18
http://www.steeda.com/products/steeda_18_street_camshaft.php
It says it made to go with the Gt40 set-up
I don't know anything except i am gonna Try it in my 5.0 HO T-Bird and get some gt40 heads and a few more extras like a typhoon intake which looks close to a Explorer Intake and hope that it all works like it says and that it might be a good set-up.
There are plenty of guys putting down 250hp to the rear wheels with a stock HO cam, GT40P heads, Explorer intake, and 1.7 roller rockers.  You may be interested in my engine build; click on the 270rwhp project link in my sig below, or you can also follow my thread on the Corral:
http://forums.corral.net/forums/showthread.php?t=1036977
I'm basically building a GT40 setup for my car; should propel me to mid 13s.
I'm basically running an Explorer motor with a cam in it in my car. I have no complaints, except that it requires a higher stall torque converter, and bigger rear tires, all of which I haven't gotten yet:hick:
Victor I'm running an Explorer motor in my car.  It has valve reliefs in the pistons.
Unless you're gonna run a wild, long, duration cam, the valve to piston clearance is BS... Clearance should be similar if not same as a HO...
Put the Stage 1 Trick Flow cam in it(what I run)... It will have a little lope at idle(likes 900-1000 rpm), and pull like crazy from 3000-6000 rpms... You'll  also need a Mass Air Setup and at least a 2400 Stall converter(a 3000-3200 is better)
If that's too wild for you, go with the stock HO cam... For the money you'd spend on something slightly better, you can buy 1.7 roller rockers...
