Topic: Steering rack install questions... (Read 2996 times) previous topic - next topic
The cost here in town is around $95.00.After the wheels,center caps,tires,shifter boot,Mobil 1 for the 5 speed,distributor module,ignition switch,fuel pump,filter,tank seals,and the steering rack,my funds are very low for the Sport.The tie rod ends I'll swap over,as they are only a few weeks old.I'll get out there this weekend and tend to it.If I take my time and take a few strategic measurements,I think it'll work.If it doesn't,then I'll have to take it in for a check.They may charge less just to check the tie rods and where they should be instead of everything else.That work has been done.
i did the thread count
then did a small adjustment by eye
goes down the road straight, and turns very well
but its not perfect
$95! :wtf:
Quote from: thunderjet302;229521
$95! :wtf:
My thoughts exactly.
Quote from: vinnietbird;229531
x3.... (I know, in American Dollars), amount paid: $45.00 (CDN) for the last front end alignment done on Salt.  :wtf: :crazy: :crazy: !
Operation: X Marks the Spot
5.0L SEFI, AOD, 8.8" 3.02 TracLok - All Stock
