Topic: Dyno run! (Read 1044 times) previous topic - next topic
Dyno run!
Peak from al three runs.
HP 171
TQ 247ft lbs
We got 7 hp and 7 ft lbs of torque by bumping timing from 10 to 14.  We didnt bump the boost because it will only hold 15... it has a bad leak at the throttle shaft.
Mods.
Deleted AC, gillis at 15, Timing at 14, K&N on the Vam, stock downpipe and y, 2.5 cat back with  flowmasters.
Next step, AFPR, 255hp pump, 65mm throttle body and ported intakes.  After that, turbo and other stuff.  This was a base line run.
comments welcome.
88 TC, Lots of Mods.
Dyno run!
Great starting spot!  I wanna do a baseline run on mine as well, so I can compare the new engine when it's done.  I'm pretty sure I'm right around 200hp at the wheels; should be at or a little above 250 at the wheels after the project.  Can't wait to see what yours does.
Dyno run!
You still have the IHI?
I'd put a big downpipe on that list of first mods, and ditch the Flowmasters (they don't work well on turbo'd engines), otherwise sounds good.
__________________
Twin '85 TCs
White/ Grey 2-tone
Dyno run!
x2 on exhaust.  I felt a major difference when I added my FMIC.  A guy gained 18hp with a Volvo front mount on his SVO!  A T3 turbo will also make you smile.  As for the TB, the biggest gain I felt was  throttle response.  However, with a gutted upper and ported lower, it's probably good for 5hp or so.
Dyno run!
Pretty good baseline for a "stock" 2.3T.
Get rid of that exhaust you have on the car, esp the FM's.  That (the exhaust) is probably the reason you only gained <10 hp/tq by bumping the boost 4psi.
I'd do the exhaust before you did the intakes/TB.
Dyno run!
By bumping the boost?  we bumped timing 4*.  .We didnt bump boost because any more that 15 it will leak bad. I agree with the lers.  Once i get the turbo and most of the other stuff done, we will dyno it again.  during that run, we are going to swap lers and see what happens.
Dyno run!
Sorry, I missread.
Dyno run!
LOL no problem.
We are going to see what a t-3 and an AFPR will do with 20 PSI.  Any guesses to the gain?
