Topic: Quick clutch pedal assembly question..... (Read 1262 times) previous topic - next topic
On the assembly,there are two red wires on the left side,and two black wires on the right side.What are they for?I'm still unbolting everything to do the swap.I'll check for an answer to this in a little while.I'm out.Oh,one more thing,what is the vacuum hose for that is connected to the assembly?
The vacume hose is for the cruise control.
Man,I'm learning all kinds of things doing this swap.Thanks.
How do you adjust the hose "switch" to the right position?
Is it to where the button is depressed when the brake pedal is not in use,then when you push the brake,it lets the button out thereby turning the cruise off?
Quote from: vinnietbird;229039
bingo....
I'll make the final adjustments tomorrow after work for that switch.Now,can you answer my other questions that I have on the drivetrain thread?
