Topic: New exhaust clip (Read 1139 times) previous topic - next topic
New exhaust clip
Yep new exhaust clip after the mass air swap. The idle is much lower (like it should be) because SD couldn't handle the cam at the stock idle setting. You can hear that the cam has a lope to it now :D
http://www.youtube.com/watch?v=8TFSHVgfgiU
New exhaust clip
Ya mines got a cam and stock exhaust and Mass air flow sensor and I had to adjust the idle to around 1250 cause the idle was set at around 750 and was wanting to stoll out but I adjusted the Idle and sounds great now.
