Topic: Engine Shake (Read 1189 times) previous topic - next topic
Engine Shake
I have a 1988 v6 and today on the way to class it started to stumble pretty hard. Under acceleration the stumble increased, almost as if a cylinder wasn't firing. I pulled the plugs and wires and everything is sparking fine. I towed it home and ran it, it cleared up a little bit by itself, and then I took it around the block. It smoked like hell for about 1/4 mile, then stopped. While smoking it was running fine, but did smell of raw gas. I added some dry gas and a bottle of fuel injector cleanner. Just incase there may have been water in the tank, although I do buy mobil gas. I thought maybe an injector was a little dirty. I only ran it for a couple of minutes after added the fluid when I cleared up. Anyone have any ideas what might have happened here?
Anything I might want to check before I drive it again?
Engine Shake
Maybe it had bad or old gas? i really don't know what to tell you i wish i did.
Engine Shake
A little more info would be nice to include.
Had the car been sitting?  Last tune-up?
Engine Shake
Tune up, check electrical system, check fuel system (leaky injector), RUN CODES ;)
Engine Shake
no codes appeared. TYhe car is driven almost daily. the last tune up was about 6 months ago. the plugs are about 3 months old tho.
Engine Shake
does it run good when it is cold? It could be MAP sensor or its vac hose.
