Topic: coolant restrictor? (Read 1965 times) previous topic - next topic
coolant restrictor?
did only the mustangs get the coolant restrictor in the
upper heater hose or did any other fox bodies? seeing
it is a lincoln part # i thought it might have made its way
into cougars or birds. its not in the replcement motorcraft
hoses but it is in the mustang one.
coolant restrictor?
-irv,
what my catalog at work tells me is the 3/4" restrictor was used on 'birds and 'cats from '84 thru '86.  they did not come with the hose when you bought it.  you had to buy them separate.  '87s and '88s did not show to use a restrictor.  if u need one now, u can order Ford part # E7VY-18D358-A.  it is stall availible....hope that helps.....
coolant restrictor?
ppi sells the restrictor . ibought the hose with it in it
for less than the restrictor.
coolant restrictor?
Quote from: irv;227835
U have linky?
coolant restrictor?
you can get it through ford [hose].
perfomancepartsinc.com
coolant restrictor?
My Sport had one,and when I installed new hoses,I kept it in use.Good little part to have.
coolant restrictor?
I used a brass fitting that fit tightly into the hot side...cost me less than $1...lol.
coolant restrictor?
I actually used an old socket.
coolant restrictor?
Quote from: V8Demon;233612
Thats what im talking about <<(myth busters voice:bowdown: )
coolant restrictor?
did the socket have a ford engineering # on it?
coolant restrictor?
Nope......13 mm , 1/4" drive that I have about 5 of....
