Topic: Vacuum canister question..... (Read 1691 times) previous topic - next topic
With the E303,do you think that a vacuum canister (saw one from Jegs) would help?Also,will they work with EFI?How do they work?
How much vacuum are you pulling at idle?  A booster only needs 12-15 inches of vacuum to work properly.
Which one you lookin at?
you dont need one with an e303
1979 Ford Fairmont
[/B]
I'll get the details about the canister and post them.I had heard that an E303 was very borderline for vacuum needs.
Borderline for what?
Meaning that the cam barely gives the Sport enough vacuum.I'm trying to figure out why the car is barely idling when I come to a stop.I have to bump it into neutral to keep it from dying at every stoplight.I hate that.It's driving me crazy.I've checked all the vacuum lines,changed the IAC,TPS,and intake gaskets.I bought one of those IAC spacer plates that is supposed to help fix the idle.I haven't tried it yet.I have to find some instructions for it.Anybody have any?
check for codes?
1979 Ford Fairmont
[/B]
what's your idle set at?  You WILL need to adjust it so that it is higher than stock.
It's up and down.LOL.It was set about 1000 to keep it running.Anything less and it wouldn't idle for very long even in Park.
