Topic: A lil help? (Read 1051 times) previous topic - next topic
A lil help?
what year ranger did i need the cam from in my 88 TC? and do i just need the cam or the complete head.....
A lil help?
Cam and followers.  89-93 with DP head.  You can use the cams after '94, but you still need earlier followers as the later ones used valves with thinner shafts...and thus the followers will not fit the valves in the turbo heads.
Or 91-93 Mustang with DP head. Same as the Ranger.
A lil help?
what is a DP head..........
A lil help?
dual plug....
A lil help?
How about a set of 4.10 gears.... can i pull those out of anything with an 8.9 rear end?
