Topic: '86 TC Running Lean (Read 1300 times) previous topic - next topic
'86 TC Running Lean
The TC has been running lean at WOT.  It seems normal at any other throttle position.  I have an Air/Fuel guage and at WOT it shows nothing.  The car bogs way down.  I have a Kirban AFPR but no matter which way or to what extent I adjust it I can't feel, see, or hear a difference.  Do I need to go to a 255 lph?
I have a K&N, '88 VAM, FMIC, 65mm TB, stock T3, 3" DP, and single 3" exhaust.
'86 TC Running Lean
Are you running a wideband air/fuel gauge? What boost are you running? and what is your FP?
1985 Thunderbird TC
2.3l .03 over,Ported and polished Head and E6 Manifold, LA3, T3/T4 Hybrid Turbo, Stinger FMIC, Forge BOV, Full 3" Exhaust, Essy Timing Gears & UDP's, BBK 255lph Fuel Pump, Kirban AFPR, Kirban Short Shifter, K&N Cone, Forced4 VC Vent Kit, PA Performance 3g Alternator, Energy Suspension Bushings throughout, CHE LCA's, SFC's [/LEFT]
'86 TC Running Lean
What pump are you running?
'86 TC Running Lean
It's the A/F gauge with the red, yellow, and green lights.  Red for lean, yellow when above "STOICH" and green for rich.  Boost is about 18psi.  I don't know what my fuel pressure is.  I *think* I'm still on the stock pump.  I haven't messed with it and I can't find a receipt for one from the previous owner who kept EVERY receipt.
'86 TC Running Lean
Regardless, you will need a 255lph high pressure pump. I don't know if that's your problem, but that's something that's just waiting to fail.
'86 TC Running Lean
Yes I would agree you need a 255lph pump, also that is a narrow band A/F gauge...they are useless. It isnt reliable and doesnt tell you anything. I wouldnt run anymore than 16 psi on a stock pump. Plus you will need to make sure you have at least 39psi stock fuel pressure vac off.
1985 Thunderbird TC
'86 TC Running Lean
Ok guys, thanks.  I'll turn the PSI down and put that 255 on the shopping list.
