Topic: Cold Air intake and Air Silencer removal (Read 1233 times) previous topic - next topic
I have a 88 turbo coupe and i was wondering what kind of cold air intake to get and how to remove the air silencer? thanks for any help
-Vic
anyone????
I'm using the MAC setup with the filter in the fender.It's been great,and it looks good too.
my apologies,I just noticed you have a TC,mine's a 5.0 car.
yea i have a TC thanks anyway
The best I've got for you is to make your own. It isn't that hard. Just remove the air box and air meter along with the bracket. Then clamp the air meter back to the hose to the turbo. Then flex it around and add some tubing to make it go through the hole where the factory air filter top got the cold air from. Then find you a Cone/Can filter and bolt it onto the tubing you extended from the air meter. There you have it a CAI. The way it looks it all up to you.
thanks that what i figured i was going to have to do i just wanted to be sure that there was not anything already made that i could use. I will look at it after work today
