Topic: turbo coupe hood?? Pics Added Page 3 (Read 5667 times) previous topic - next topic
i have an 85 t-bird, does the 87 - 88 turbo coupe hood fit it
the one with the vents i mean
Same hinges
if you have a 5.0 you need to fix the alt bracket by grinding it down. Especially if you have a shot motor mount. Check out coolcats.net in the tech section.
I have an 85 bird that had a 3.8 v6.... I purchased an 87 TC hood and it bolted right up.  No mods.  It looks so much better too!  I love it.  Hung my old hood on my garage wall.
===85BIRD===
:birdsmily:
it hits on the vent. I didnt think it would matter till my motor mount went and broke it right out. You just need to grind down on it alittle bit to get extra clearance. Have you never had a car with a big bump in the hood from the alt bracket?
ac bracket.
whoops... I ment ac... sorry...
Ok, my question is when I get the hood (tc) and put it on my 86 5.0. It says i will need the inserts for the vent to keep water from dumping on the dist. Now here's the kicker wouldn't ford have design the hood not to allow that and if not aren't there some inserts that will prevent water from coming in, but not air?
[SIGPIC][/SIGPIC]86 COUGAR LS 5.0 stock. Soon to be project "Cheetara"
85 Ramcharger 318-727 "Big Girl"
Ford didn't design the hood for a V-8 and dumping water on the distributor wouldn't be an issue for the 4 banger.The TC would have the ducting installed.For a V-8,the ducting won't fit.I made block off plates from aluminum to prevent the issues of anything coming through the scoops onto my engine.
Yep, and Vinnie is going to start making them so we all have nice ones like him... huh, vinnie.
(just kidding, don't bother Vin about it.)  Although I'd be willing to pay $25 for a pair....
===85BIRD===
:birdsmily:
I cut plexie glass and glued them on.with little drain holes,got tired of washing the car down hill.
