Topic: cuttin in turns (Read 3047 times) previous topic - next topic
cuttin in turns
my power is cutting severely, so bad that the motor will die and will not turn back on for 30 seconds!, when you are turning into traffic thats a loooong time!!! anyone else have this prob??
:burnout:  GET SOME!!!!!  :burnout:
cuttin in turns
Are you saying the entire car shuts down, electronics and all, or just the motor stall?
More info?
cuttin in turns
at the start it just stalled and now gradually it's getting more severe and not just in the turns now! not the electrical just motor, i've heard it could be the computer, but not sure?? HELP!!! please
cuttin in turns
You are running out of gas.
LOL Just Kidding.  It could be a flaky ......... wait....... did the 84's have the fuel cutoff?
88 TC, Lots of Mods.
cuttin in turns
Not electrical huh???
Chuck, think maybe he has a diesel with a mechanical injection pump???
cuttin in turns
You've "heard" it could be the computer?
Who told you that?
We don't have enough info to help you, period.  We're not mind readers, you have to give us more info.
Does it restart right away when it stalls?  What exactly happens when it's "cutting out"?
cuttin in turns
i hear a chattering noise and then it will cut... i have taken the passenger's side interior apart to hear where it is coming from more clearly, a redneck mechanic told me it could be the computer because that's where the chattering is comming from, it will take a few seconds to restart it but yes it will restart, i just filled the tank so its not gas! haha
cuttin in turns
The computer isn't going to make ANY noise... Possibly the EEC power relay or the related wiring has a problem causing it to chatter...
cuttin in turns
would that be causing the car to cut out though?
cuttin in turns
If you are hearing "chattering" it's the relay as mentioned.
What the issue sounds like the EEC relay is getting intermittent power...which points to a possible ignition switch issue (the steering column). They are a known fail point on '80's Fords.  If the power is intermittent to the EEC relay, it will click.  It also means the ECU is getting  intermittent power...thus your stalling.
Oh, and stop listening to redneck mechanics....
cuttin in turns
lol so how to stop from getting the other power??? get a new relay?
cuttin in turns
Quote from: 84cougarV8;225065
:shakehead :shakehead :shakehead :shakehead
Read Chuck's post again(and again if necessary)... May not be the problem, but is no doubt the first possibility which should be  eliminated...
cuttin in turns
well it wasnt the relay.... anything else possible?
cuttin in turns
You didn't read my post...otherwise your last post would have read,
"well it wasnt the ignition switch..."
cuttin in turns
is that a for sure thing though?? mu budget is sooooooo busted right now! or maybe the %?
