Topic: 1986 T-bird restoration in progress.... Second restoration!!!!"Picture update" (Read 34238 times) previous topic - next topic
finally something to update!!!
Reply #105
finally finished my stainless dash inlay well was waiting 3 weeks for the correct size hole saw blades. what do you all think
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Reply #106
nice! I can't wait to see it installed, good job
Reply #107
Very nice !!!! Are you going to install a blue light for the bright light indicator?Beautiful work.
Reply #108
I cant decide I had that on the aluminum one
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Reply #109
Mounted, now I have to make an inlay for the radio,a/c pannel and 3 more guages over the radio
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Reply #110
Looks great, and you even replaced the clock. +1 for seeing it installed.
Matt
Reply #111
yeah the clock is a nice touch!
Reply #112
My friend and I made an aluminum dash for his truck...I can't remember how we did it but we made it "turned aluminum" with those little swirls in it.  I think we just took a big drill bit and barely touched it over and over.  It looked pretty cool and old school.
Like this...
http://www.sharp-concepts.com/Pickguards/EngineTurnClose.JPG
Reply #113
that would look good but I am trying to go with a more modern look then an old school look. You can use a wire wheel in a drill press or a scotch brite wheel for results like that
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Reply #114
Eh,just an idea.  I like everything you've done so far.  Keep up the good work!!
Reply #115
yeah looks great!!
[/IMG]
Just enjoyin the ride!!!!
Reply #116
ok almost done with the interior
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Reply #117
That clock is sick!! I never knew that was available. Everything is coming along very nicely.
Reply #118
(Homer) mmmmmm, Hammer shifter!!! (Homer) :burnout:
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Reply #119
well lookie what I got $140 braces foe $30 shipped on ebay can't believe it been looking for some for a long time. Now I don't have to use my 4 ft. level to hold the hood up.
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
