Topic: MS + EDIS = No Start (Read 866 times) previous topic - next topic
I got everything installed tonight.  Bamafuel setup, consisting of the adapter board and MS box.  Got everything wired up (with a few uncertainties, see below), got the vac line hooked up to the MS box and tried to start her.  She turns over, but doesn't seem to be firing.  I ran the PIP and SAW wires over to the TFI plug where the PIP and SPOUT connections are.
I pretty much followed the pic in this link, with the following exceptions:
http://www.megamanual.com/ms2/edis4ew.gif
-Unsure about VR sensor polarity
-Coil pack pigtail (3 pin), followed the diagram, but the wire colors are backwards from what it looks like they should be (they would match if I switched them around)
-No 25 uF cap
-VR sensor is about 2-3 mm away from the 36-1 wheel.
-No shielded wire from VR sensor to EDIS module (figured for the time being it would at least get the car started)
I haven't set the computer to 75 pound injectors, which is what I have now, and haven't changed any startup enrichment settings.
Could any of the above be obvious cuprits to not firing?  Any other things to try/troubleshoot?
