Topic: Mustang shock problem fix (Read 1482 times) previous topic - next topic
I was going to buy chuck's adapters but they were not available at the time I needed them so I decided to weld them. I cut the little tab off and knocked out the stud out wich I filled with weld and then welded around the edges should work great. What do you guys think now I have a spot to mount my straps when I trailer it to the track.I have more pictures but I have to find them, sorry its so dusty I have been sanding on the car A LOT!!!!! LOL
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
How do you like the Strange shocks?  Do you have their struts?
have not driven the car with the shocks but I have their struts and they are awesome I like being able to adjust them when ever I want
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
more pictures
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
