Topic: brake line lock on TC? (Read 1476 times) previous topic - next topic
I got an 88 tc, and am in the process of doing big turbo and ported everything.  I was figuring while I actually had room to get to the brake master cylinder and abs unit, I would put my brake line lock in.  Well, how does that work, the brake fluid comes out the end of the master cylinder directly into the abs unit bolted to it:punchballs:
So... how do I end up getting this hooked up or do I have to order a second solenoid to be able to keep the abs working right?
Most of the hillbillies will be like "gaw get reed uh that abs  *spit tobaccy*".
You should see what I'm lookin fly and rollin phat in right now dude.
ooh, ooh, a festiva?
Yeeeeeahh boyeeee
Quote from: fordguy545;224220
Since braking can be modulated by the ABS for each wheel, only way I know of...   :hick:
