Topic: tire size (Read 2534 times) previous topic - next topic
tire size
will 295/50/15 fit underneath a cougar on the rear or do you have to do alot of work for them to fit? i had 275/60/15 they fit pretty good with out rubbing.
tire size
on what rim?
tire size
I would guess a 15" judging by his post.
tire size
I'd hope about 11" wide.
tire size
I had these under my car for about 1 week on a set of 10" wide weld wheels with the stock rear. I think they had a 4.5" back spacing. These were my brother so I do not know any more info about the wheels. I was rubbing the fender lip (on the side walls) when the car twisted. I could have fixed that by changing the rear springs or putting a couple spacers in the springs.
Our web page
02 Explorer XLT 4.0L
04 F150 FX4 Supercrew 5.4L
02 Saturn SL1 1.9L
09 Vstar 950 Tourer
tire size
the wheel right now are turbines till i get weld wheels. but i was just curious if that size would fit?
tire size
I believe that I have read that Blown306Cougar (Nick) had this size on the a set of 10 holes before getting welds. Do not know if there where any issues of rubbing.
Our web page
02 Saturn SL1 1.9L
09 Vstar 950 Tourer
tire size
A 295 is WAAAYYY too wide for a 7" wheel.
tire size
245/ 50 on a 7in are suppose to bulge in the middle so 295...
tire size
The ideal tire for a 7" wheel is a 205.
tire size
236/60's fit nice on the turbines, wouldn't go much wider on a 7" wheel
tire size
i have 275/60/15 and its not bulging at all on turbines. my question was would 295/50/15 fit underneath the back of a cougar. that wide of tire i wouldnt put on a turbine. i planned on putting them on weld wheels if they would fit underneath the rear without rubbing.
