Topic: Fuel pump (Read 2139 times) previous topic - next topic
Fuel pump
I didnt get an answer from my other post so I'll ask again. I have an 85 XR7 that I am swapping a 302 into can I still use the old fuel pump or do I need to step up to an inline pump or something? Anything would help.
Fuel pump
NO you need to use a mechanical pump or a low pressure inline.
Simple enough i think!
Fuel pump
Is the 302 EFI or carb?
Fuel pump
And when you answer this THEN you can get the correct answer =)
Fuel pump
He did mention in another thread that for some reason he is going carbed????
Lack of experience to do the efi swap i'm guessing.
Fuel pump
hey now, there is nothing wrong with carbs....  I love my capris carbed motor.
Fuel pump
Yes, you can run the electric pump on the car with a carb. You just need to use a pressure regulator, such as the ones made by Holley. I ran this setup on my old '86 Cougar with a carbed 351w. :burnout:
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Fuel pump
What regulator did you use that will take 100psi down to 5-6????
Fuel pump
What stock style pump puts out 100 PSI?
I don't think anyone put down carb motors.
Fuel pump
Quote from: V8Demon;224202
Dead ended, any of them... As mentioned there are regulators which can lower pressure, guessing a return to the tank is still required...
Fuel pump
me and Chris use to hang out quite abit and I know he prefers the Fuelie over the carbs, especially since he was bugging me to do a fuelie swap on the Capri.:mullet:
Fuel pump
Quote from: dominator;224185
This is like the one I used. Pressure line in one, return line out, carb feed out of the other. :burnout:
Fuel pump
mmmm  wasn't thinking of that!
